Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gemini: VIDEO: express basics training: How to Connect Ethernet (includes Win7)
How to enable ethernet (TCP/IP) communication for the 6K and Gem6K (GV6K/GT6K) products.
Shows some basic commands to query controller error report & axis status.
Also shows the equipment required.
For how to upload/download motor configuration and programs with MotionPlanner, see this FAQ: VIDEO: express basics training: GV6K or GT6K drive controllers
