Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Training - I10T10 Training Videos
Free online training on how to connect and configure the Compax3 I10T10 servo drives.
The I10T10 is the base servo amplifier that supports analog torque or velocity mode (+/- 10vdc) with encoder feedback to the controller, Position (step & direction: 5 volt or 24 volt) with optional encoder feedback, or encoder following mode (standard quadrature encoder input or SSI encoder input)
MOBILE USERS CLICK HERE
Playlist of all I10T10 videos or individual videos below:
Note these videos are hosted in youtube.com and would require access to this site. This is a 14 part video training in this play list. For first time users, it'd be good to watch all in sequence. For experienced users needing a refresher or looking for specific information, the lessons are broken in small sections so you wouldn't need to watch all. Total time is 19 minutes. Individual videows are below:
Alternately, these videos can be downloaded from here for PCs without internet connection:
http://www.parkermotion.com/manuals/hauser/compax3/Compax3.htm
Lesson 1: C3 ServoManager
Lesson 2: Drive Selection
Lesson 3: Drive Configuration
Lesson 4: Motor Selection
Lesson 5: Motor Reference Data
Lesson 6: Braking Resistor
7 skipped
Lesson 8: Command Interface
Lesson 9: Analog Scaling / Drive resolution, Encoder Output Resolution
Lesson 10: Ramp In, Ramp Out
Lesson 11: Monitoring (Torque/Speed Limits)
Lesson 12: Summary Screen
Lesson 13: Download Screen
Lesson 14: Making Motion I10T10
keywords:
S025V2F10I10T10M00
S063V2F10I10T10M00
S038V4F10I10T10M00
S075V4F10I10T10M00
S100V2F10I10T10M00
S150V2F10I10T10M00
S150V4F10I10T10M00
S300V4F10I10T10M00
H50V4F10I10T10M00
H90V4F10I10T10M00
H125V4F10I10T10M00
H155V4F10I10T10M00
M050D6F10I10T10M00
M100D6F10I10T10M00
M150D6F10I10T10M00
M300D6F10I10T10M00
S025V2F12I10T10M00
S063V2F12I10T10M00
S038V4F12I10T10M00
S075V4F12I10T10M00
S100V2F12I10T10M00
S150V2F12I10T10M00
S150V4F12I10T10M00
S300V4F12I10T10M00
H50V4F12I10T10M00
H90V4F12I10T10M00
H125V4F12I10T10M00
H155V4F12I10T10M00
M050D6F12I10T10M00
M100D6F12I10T10M00
M150D6F12I10T10M00
M300D6F12I10T10M00
S025V2F11I10T10M00
S063V2F11I10T10M00
S038V4F11I10T10M00
S075V4F11I10T10M00
S100V2F11I10T10M00
S150V2F11I10T10M00
S150V4F11I10T10M00
S300V4F11I10T10M00
H50V4F11I10T10M00
H90V4F11I10T10M00
H125V4F11I10T10M00
H155V4F11I10T10M00
M050D6F11I10T10M00
M100D6F11I10T10M00
M150D6F11I10T10M00
M300D6F11I10T10M00
