Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (230VAC Encoder & Resolver) to Parker MPP
The MPP (MaxPlusPlus) Series is the industry's highest performing servo motor. Utilizing eight-pole segmented lamination technology, the MPP produces more torque in a shorter package. Use MPP motors for higher torque applications, customization options, or when high performance is required.
The MPP Series features a new design that offers lower inertia and higher power, all in a smaller motor package. These brushless servo motors are designed for the demanding applications found in today's high performance servo systems.
The MPP motors feature segmented core technology, which can yield up to 40% higher torque per unit size than conventionally wound servo motors. Potted stators improve heat transfer for better thermal efficiency, resulting in increased torque at the motor shaft.
High-energy neodymium magnets are employed for higher rates of acceleration.
Parker will customize any MPP motor to meet your specific system requirements. Parker does customs like no one else. We are specialists at customs, offering unrivaled custom motor solutions and support.
The MPP/MPJ family of brushless servo motors redefines performance, flexibility, and reliability.
Feedback Notes:
Numerous applications have used the Kinetix drives with the MPP and MPJ series motors with our standard single-speed resolver (41) and 2000-line (pre-quadrature) encoder (1E) with hall sensors.
Absolute Encoder Notes:
The MPP and MPJ with the Compax3 support the full range of the absolute encoders of 4096 turns and support absolute position retention when the drive has been powered off.
Are MPP / MPJ with absolute encoders compatible with Kinetix drives?
MPL series motors with M are a multi-turn Stegmann Hiperface absolute encoder (4096 turns). The MPP series motors with 6S are the same model Stegmann Hiperface absolute encoder (SRM 50). Kinetix drives use a blob file that's sent from the Hiperface absolute encoder for their auto-configuration. The MPP use the standard Hiperface encoder without this blob file. Thus MPP motors with the Stegmann Hiperface multi-turn (6S) or single-turn (9S) are compatible with Parker Compax3 drives with F11 but not Kinetix drives.
Kinetix drives 300 do not support third-party motors. For 350 drives, you can check with your AB representative.
Kinetix 6200 support third-party motors with EnDat with firmware version 1.040:
Kinetix 6200 firmware note 1
Kinetix 6200 firmware note 2
Kinetix 6500 support third-party motors with EnDat with firmware version 2.005:
Kinetix 6500 firmware note 1
Kinetix 6500 firmware note 2
MPP and MPJ servo motors are available with EnDat 2.1 encoder (ECI 1331) and is the 7D order code. ie, MPP0921B7D-NPSN Note the limited Kinetix ability in using the absolute encoder function in power-off (above notes). Note the drive and cable differences per this FAQ if using Parker Compax3:
FAQ: Absolute Encoders and Drive Compatibility
Connector Notes:
Initially the MPL series motors had fixed connectors, Circular Bayonet, Facing Shaft. This was connector 2 in the part numbering: MPL-A330P-MJ22AA. Allen Bradley now has the MPL series with Circular (SpeedTec) DIN connector, right-angle 180 degree rotatable, similar style as the MPP series motor. This is connector 7 in the part numbering: MPL-A330P-MJ72AA
Click here for Compax3 Input and Control Technology Levels  (IxxTxxMxx options)
Disclaimer: This has been developed as a guide for cross referencing MPL motors to Parker motors. The motors should not be used for final motor selection unless reviewed and approved by an automation engineer. The customer is ultimately responsible for their machine design.
To use this table, hold Control key and press F. Text find will appear, something that looks like this:
Enter the MPL motor part number. The Parker motor and drive options are listed as well as the motor power and feedback cables.
Allen Bradley Rockwell P/N Parker P/N feedback Parker Compax3S Single Axis Servo Drive* Parker Compax3M Multi Axis Servo Drive* Motor Power Cable P/N Feedback Cable P/N for Compax3 Feedback Cable P/N flying leads
MPL-A310P MPP0921C
MPL-A310P-HJ22AA MPP0921C1E-KPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HJ24AA MPP0921C1E-KPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HJ72AA MPP0921C1E-KPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HJ74AA MPP0921C1E-KPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HK22AA MPP0921C1E-NPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HK24AA MPP0921C1E-NPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HK72AA MPP0921C1E-NPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-HK74AA MPP0921C1E-NPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310P-RJ22AA MPP0921C41-KPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RJ24AA MPP0921C41-KPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RJ72AA MPP0921C41-KPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RJ74AA MPP0921C41-KPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RK22AA MPP0921C41-NPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RK24AA MPP0921C41-NPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RK72AA MPP0921C41-NPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310P-RK74AA MPP0921C41-NPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F MPP0921B
MPL-A310F-HJ22AA MPP0921B1E-KPSN S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HJ24AA MPP0921B1E-KPSB S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HJ72AA MPP0921B1E-KPSN S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HJ74AA MPP0921B1E-KPSB S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HK22AA MPP0921B1E-NPSN S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HK24AA MPP0921B1E-NPSB S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HK72AA MPP0921B1E-NPSN S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-HK74AA MPP0921B1E-NPSB S025V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A310F-RJ22AA MPP0921B41-KPSN S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RJ24AA MPP0921B41-KPSB S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RJ72AA MPP0921B41-KPSN S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RJ74AA MPP0921B41-KPSB S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RK22AA MPP0921B41-NPSN S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RK24AA MPP0921B41-NPSB S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RK72AA MPP0921B41-NPSN S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A310F-RK74AA MPP0921B41-NPSB S025V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P MPP0922D
MPL-A320P-HJ22AA MPP0922D1E-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HJ24AA MPP0922D1E-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HJ72AA MPP0922D1E-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HJ74AA MPP0922D1E-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HK22AA MPP0922D1E-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HK24AA MPP0922D1E-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HK72AA MPP0922D1E-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-HK74AA MPP0922D1E-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320P-RJ22AA MPP0922D41-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RJ24AA MPP0922D41-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RJ72AA MPP0922D41-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RJ74AA MPP0922D41-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RK22AA MPP0922D41-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RK24AA MPP0922D41-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RK72AA MPP0922D41-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320P-RK74AA MPP0922D41-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H MPP0922C
MPL-A320H-HJ22AA MPP0922C1E-KPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HJ24AA MPP0922C1E-KPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HJ72AA MPP0922C1E-KPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HJ74AA MPP0922C1E-KPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HK22AA MPP0922C1E-NPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HK24AA MPP0922C1E-NPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HK72AA MPP0922C1E-NPSN S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-HK74AA MPP0922C1E-NPSB S063V2F12IxxTxxMxx M050D6F12IxxTxxMxx P-1A1-xx F-2C1-xx F-9F1-xx
MPL-A320H-RJ22AA MPP0922C41-KPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RJ24AA MPP0922C41-KPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RJ72AA MPP0922C41-KPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RJ74AA MPP0922C41-KPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RK22AA MPP0922C41-NPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RK24AA MPP0922C41-NPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RK72AA MPP0922C41-NPSN S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A320H-RK74AA MPP0922C41-NPSB S063V2F10IxxTxxMxx M050D6F10IxxTxxMxx P-1A1-xx F-2B1-xx F-9F1-xx
MPL-A330P MPP0923D
MPL-A330P-HJ22AA MPP0923D1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HJ24AA MPP0923D1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HJ72AA MPP0923D1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HJ74AA MPP0923D1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HK22AA MPP0923D1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HK24AA MPP0923D1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HK72AA MPP0923D1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-HK74AA MPP0923D1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A330P-RJ22AA MPP0923D41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RJ24AA MPP0923D41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RJ72AA MPP0923D41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RJ74AA MPP0923D41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RK22AA MPP0923D41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RK24AA MPP0923D41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RK72AA MPP0923D41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A330P-RK74AA MPP0923D41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P MPP1002D
MPL-A420P-HJ22AA MPP1002D1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HJ24AA MPP1002D1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HJ72AA MPP1002D1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HJ74AA MPP1002D1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HK22AA MPP1002D1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HK24AA MPP1002D1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HK72AA MPP1002D1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-HK74AA MPP1002D1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A420P-RJ22AA MPP1002D41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RJ24AA MPP1002D41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RJ72AA MPP1002D41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RJ74AA MPP1002D41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RK22AA MPP1002D41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RK24AA MPP1002D41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RK72AA MPP1002D41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A420P-RK74AA MPP1002D41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P MPP1003D
MPL-A430P-HJ22AA MPP1003D1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HJ24AA MPP1003D1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HJ72AA MPP1003D1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HJ74AA MPP1003D1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HK22AA MPP1003D1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HK24AA MPP1003D1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HK72AA MPP1003D1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-HK74AA MPP1003D1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430P-RJ22AA MPP1003D41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RJ24AA MPP1003D41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RJ72AA MPP1003D41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RJ74AA MPP1003D41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RK22AA MPP1003D41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RK24AA MPP1003D41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RK72AA MPP1003D41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430P-RK74AA MPP1003D41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H MPP1003C
MPL-A430H-HJ22AA MPP1003C1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HJ24AA MPP1003C1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HJ72AA MPP1003C1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HJ74AA MPP1003C1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HK22AA MPP1003C1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HK24AA MPP1003C1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HK72AA MPP1003C1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-HK74AA MPP1003C1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A430H-RJ22AA MPP1003C41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RJ24AA MPP1003C41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RJ72AA MPP1003C41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RJ74AA MPP1003C41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RK22AA MPP1003C41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RK24AA MPP1003C41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RK72AA MPP1003C41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A430H-RK74AA MPP1003C41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P MPP1152D
MPL-A4520P-HJ22AA MPP1152D1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HJ24AA MPP1152D1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HJ72AA MPP1152D1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HJ74AA MPP1152D1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HK22AA MPP1152D1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HK24AA MPP1152D1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HK72AA MPP1152D1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-HK74AA MPP1152D1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520P-RJ22AA MPP1152D41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RJ24AA MPP1152D41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RJ72AA MPP1152D41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RJ74AA MPP1152D41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RK22AA MPP1152D41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RK24AA MPP1152D41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RK72AA MPP1152D41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520P-RK74AA MPP1152D41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K MPP1152C
MPL-A4520K-HJ22AA MPP1152C1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HJ24AA MPP1152C1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HJ72AA MPP1152C1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HJ74AA MPP1152C1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HK22AA MPP1152C1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HK24AA MPP1152C1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HK72AA MPP1152C1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-HK74AA MPP1152C1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4520K-RJ22AA MPP1152C41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RJ24AA MPP1152C41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RJ72AA MPP1152C41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RJ74AA MPP1152C41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RK22AA MPP1152C41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RK24AA MPP1152C41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RK72AA MPP1152C41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4520K-RK74AA MPP1152C41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K MPP1153C
MPL-A4530K-HJ22AA MPP1153C1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ24AA MPP1153C1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ72AA MPP1153C1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ74AA MPP1153C1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK22AA MPP1153C1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK24AA MPP1153C1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK72AA MPP1153C1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK74AA MPP1153C1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-RJ22AA MPP1153C41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ24AA MPP1153C41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ72AA MPP1153C41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ74AA MPP1153C41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK22AA MPP1153C41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK24AA MPP1153C41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK72AA MPP1153C41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK74AA MPP1153C41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530F MPP1153B
MPL-A4530K-HJ22AA MPP1153B1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ24AA MPP1153B1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ72AA MPP1153B1E-KPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HJ74AA MPP1153B1E-KPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK22AA MPP1153B1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK24AA MPP1153B1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK72AA MPP1153B1E-NPSN S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-HK74AA MPP1153B1E-NPSB S100V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4530K-RJ22AA MPP1153B41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ24AA MPP1153B41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ72AA MPP1153B41-KPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RJ74AA MPP1153B41-KPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK22AA MPP1153B41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK24AA MPP1153B41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK72AA MPP1153B41-NPSN S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4530K-RK74AA MPP1153B41-NPSB S100V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C MPP1154A
MPL-A4540C-HJ22AA MPP1154A1E-KPSN S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HJ24AA MPP1154A1E-KPSB S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HJ72AA MPP1154A1E-KPSN S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HJ74AA MPP1154A1E-KPSB S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HK22AA MPP1154A1E-NPSN S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HK24AA MPP1154A1E-NPSB S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HK72AA MPP1154A1E-NPSN S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-HK74AA MPP1154A1E-NPSB S063V2F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540C-RJ22AA MPP1154A41-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RJ24AA MPP1154A41-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RJ72AA MPP1154A41-KPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RJ74AA MPP1154A41-KPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RK22AA MPP1154A41-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RK24AA MPP1154A41-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RK72AA MPP1154A41-NPSN S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540C-RK74AA MPP1154A41-NPSB S063V2F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F MPP1154B
MPL-A4540F-HJ22AA MPP1154B1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HJ24AA MPP1154B1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HJ72AA MPP1154B1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HJ74AA MPP1154B1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HK22AA MPP1154B1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HK24AA MPP1154B1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HK72AA MPP1154B1E-NPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-HK74AA MPP1154B1E-NPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A4540F-RJ22AA MPP1154B41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RJ24AA MPP1154B41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RJ72AA MPP1154B41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RJ74AA MPP1154B41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RK22AA MPP1154B41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RK24AA MPP1154B41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RK72AA MPP1154B41-NPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A4540F-RK74AA MPP1154B41-NPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K MPP1422C
MPL-A520K-HJ22AA MPP1422C1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HJ24AA MPP1422C1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HJ72AA MPP1422C1E-KPSN S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HJ74AA MPP1422C1E-KPSB S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HK22AA MPP1422C1E-KPSN* S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HK24AA MPP1422C1E-KPSB* S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HK72AA MPP1422C1E-KPSN* S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-HK74AA MPP1422C1E-KPSB* S150V2F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-A520K-RJ22AA MPP1422C41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RJ24AA MPP1422C41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RJ72AA MPP1422C41-KPSN S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RJ74AA MPP1422C41-KPSB S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RK22AA MPP1422C41-KPSN* S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RK24AA MPP1422C41-KPSB* S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RK72AA MPP1422C41-KPSN* S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A520K-RK74AA MPP1422C41-KPSB* S150V2F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-A540K MPP1424C
MPL-A540K-HJ22AA MPP1424C1E-KPSN S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HJ24AA MPP1424C1E-KPSB S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HJ72AA MPP1424C1E-KPSN S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HJ74AA MPP1424C1E-KPSB S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HK22AA MPP1424C1E-KPSN* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HK24AA MPP1424C1E-KPSB* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HK72AA MPP1424C1E-KPSN* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-HK74AA MPP1424C1E-KPSB* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A540K-RJ22AA MPP1424C41-KPSN S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RJ24AA MPP1424C41-KPSB S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RJ72AA MPP1424C41-KPSN S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RJ74AA MPP1424C41-KPSB S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RK22AA MPP1424C41-KPSN* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RK24AA MPP1424C41-KPSB* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RK72AA MPP1424C41-KPSN* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A540K-RK74AA MPP1424C41-KPSB* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F MPP1426B
MPL-A560F-HJ22AA MPP1426B1E-KPSN S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HJ24AA MPP1426B1E-KPSB S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HJ72AA MPP1426B1E-KPSN S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HJ74AA MPP1426B1E-KPSB S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HK22AA MPP1426B1E-KPSN* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HK24AA MPP1426B1E-KPSB* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HK72AA MPP1426B1E-KPSN* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-HK74AA MPP1426B1E-KPSB* S300V2F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-A560F-RJ22AA MPP1426B41-KPSN S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RJ24AA MPP1426B41-KPSB S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RJ72AA MPP1426B41-KPSN S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RJ74AA MPP1426B41-KPSB S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RK22AA MPP1426B41-KPSN* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RK24AA MPP1426B41-KPSB* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RK72AA MPP1426B41-KPSN* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-A560F-RK74AA MPP1426B41-KPSB* S300V2F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
9/9/13 jh
MPLA310P
MPLA310PHJ22AA
MPLA310PHJ24AA
MPLA310PHJ72AA
MPLA310PHJ74AA
MPLA310PHK22AA
MPLA310PHK24AA
MPLA310PHK72AA
MPLA310PHK74AA
MPLA310PRJ22AA
MPLA310PRJ24AA
MPLA310PRJ72AA
MPLA310PRJ74AA
MPLA310PRK22AA
MPLA310PRK24AA
MPLA310PRK72AA
MPLA310PRK74AA
MPLA310F
MPLA310FHJ22AA
MPLA310FHJ24AA
MPLA310FHJ72AA
MPLA310FHJ74AA
MPLA310FHK22AA
MPLA310FHK24AA
MPLA310FHK72AA
MPLA310FHK74AA
MPLA310FRJ22AA
MPLA310FRJ24AA
MPLA310FRJ72AA
MPLA310FRJ74AA
MPLA310FRK22AA
MPLA310FRK24AA
MPLA310FRK72AA
MPLA310FRK74AA
MPLA320P
MPLA320PHJ22AA
MPLA320PHJ24AA
MPLA320PHJ72AA
MPLA320PHJ74AA
MPLA320PHK22AA
MPLA320PHK24AA
MPLA320PHK72AA
MPLA320PHK74AA
MPLA320PRJ22AA
MPLA320PRJ24AA
MPLA320PRJ72AA
MPLA320PRJ74AA
MPLA320PRK22AA
MPLA320PRK24AA
MPLA320PRK72AA
MPLA320PRK74AA
MPLA320H
MPLA320HHJ22AA
MPLA320HHJ24AA
MPLA320HHJ72AA
MPLA320HHJ74AA
MPLA320HHK22AA
MPLA320HHK24AA
MPLA320HHK72AA
MPLA320HHK74AA
MPLA320HRJ22AA
MPLA320HRJ24AA
MPLA320HRJ72AA
MPLA320HRJ74AA
MPLA320HRK22AA
MPLA320HRK24AA
MPLA320HRK72AA
MPLA320HRK74AA
MPLA330P
MPLA330PHJ22AA
MPLA330PHJ24AA
MPLA330PHJ72AA
MPLA330PHJ74AA
MPLA330PHK22AA
MPLA330PHK24AA
MPLA330PHK72AA
MPLA330PHK74AA
MPLA330PRJ22AA
MPLA330PRJ24AA
MPLA330PRJ72AA
MPLA330PRJ74AA
MPLA330PRK22AA
MPLA330PRK24AA
MPLA330PRK72AA
MPLA330PRK74AA
MPLA420P
MPLA420PHJ22AA
MPLA420PHJ24AA
MPLA420PHJ72AA
MPLA420PHJ74AA
MPLA420PHK22AA
MPLA420PHK24AA
MPLA420PHK72AA
MPLA420PHK74AA
MPLA420PRJ22AA
MPLA420PRJ24AA
MPLA420PRJ72AA
MPLA420PRJ74AA
MPLA420PRK22AA
MPLA420PRK24AA
MPLA420PRK72AA
MPLA420PRK74AA
MPLA430P
MPLA430PHJ22AA
MPLA430PHJ24AA
MPLA430PHJ72AA
MPLA430PHJ74AA
MPLA430PHK22AA
MPLA430PHK24AA
MPLA430PHK72AA
MPLA430PHK74AA
MPLA430PRJ22AA
MPLA430PRJ24AA
MPLA430PRJ72AA
MPLA430PRJ74AA
MPLA430PRK22AA
MPLA430PRK24AA
MPLA430PRK72AA
MPLA430PRK74AA
MPLA430H
MPLA430HHJ22AA
MPLA430HHJ24AA
MPLA430HHJ72AA
MPLA430HHJ74AA
MPLA430HHK22AA
MPLA430HHK24AA
MPLA430HHK72AA
MPLA430HHK74AA
MPLA430HRJ22AA
MPLA430HRJ24AA
MPLA430HRJ72AA
MPLA430HRJ74AA
MPLA430HRK22AA
MPLA430HRK24AA
MPLA430HRK72AA
MPLA430HRK74AA
MPLA4520P
MPLA4520PHJ22AA
MPLA4520PHJ24AA
MPLA4520PHJ72AA
MPLA4520PHJ74AA
MPLA4520PHK22AA
MPLA4520PHK24AA
MPLA4520PHK72AA
MPLA4520PHK74AA
MPLA4520PRJ22AA
MPLA4520PRJ24AA
MPLA4520PRJ72AA
MPLA4520PRJ74AA
MPLA4520PRK22AA
MPLA4520PRK24AA
MPLA4520PRK72AA
MPLA4520PRK74AA
MPLA4520K
MPLA4520KHJ22AA
MPLA4520KHJ24AA
MPLA4520KHJ72AA
MPLA4520KHJ74AA
MPLA4520KHK22AA
MPLA4520KHK24AA
MPLA4520KHK72AA
MPLA4520KHK74AA
MPLA4520KRJ22AA
MPLA4520KRJ24AA
MPLA4520KRJ72AA
MPLA4520KRJ74AA
MPLA4520KRK22AA
MPLA4520KRK24AA
MPLA4520KRK72AA
MPLA4520KRK74AA
MPLA4530K
MPLA4530KHJ22AA
MPLA4530KHJ24AA
MPLA4530KHJ72AA
MPLA4530KHJ74AA
MPLA4530KHK22AA
MPLA4530KHK24AA
MPLA4530KHK72AA
MPLA4530KHK74AA
MPLA4530KRJ22AA
MPLA4530KRJ24AA
MPLA4530KRJ72AA
MPLA4530KRJ74AA
MPLA4530KRK22AA
MPLA4530KRK24AA
MPLA4530KRK72AA
MPLA4530KRK74AA
MPLA4530F
MPLA4530KHJ22AA
MPLA4530KHJ24AA
MPLA4530KHJ72AA
MPLA4530KHJ74AA
MPLA4530KHK22AA
MPLA4530KHK24AA
MPLA4530KHK72AA
MPLA4530KHK74AA
MPLA4530KRJ22AA
MPLA4530KRJ24AA
MPLA4530KRJ72AA
MPLA4530KRJ74AA
MPLA4530KRK22AA
MPLA4530KRK24AA
MPLA4530KRK72AA
MPLA4530KRK74AA
MPLA4540C
MPLA4540CHJ22AA
MPLA4540CHJ24AA
MPLA4540CHJ72AA
MPLA4540CHJ74AA
MPLA4540CHK22AA
MPLA4540CHK24AA
MPLA4540CHK72AA
MPLA4540CHK74AA
MPLA4540CRJ22AA
MPLA4540CRJ24AA
MPLA4540CRJ72AA
MPLA4540CRJ74AA
MPLA4540CRK22AA
MPLA4540CRK24AA
MPLA4540CRK72AA
MPLA4540CRK74AA
MPLA4540F
MPLA4540FHJ22AA
MPLA4540FHJ24AA
MPLA4540FHJ72AA
MPLA4540FHJ74AA
MPLA4540FHK22AA
MPLA4540FHK24AA
MPLA4540FHK72AA
MPLA4540FHK74AA
MPLA4540FRJ22AA
MPLA4540FRJ24AA
MPLA4540FRJ72AA
MPLA4540FRJ74AA
MPLA4540FRK22AA
MPLA4540FRK24AA
MPLA4540FRK72AA
MPLA4540FRK74AA
MPLA520K
MPLA520KHJ22AA
MPLA520KHJ24AA
MPLA520KHJ72AA
MPLA520KHJ74AA
MPLA520KHK22AA
MPLA520KHK24AA
MPLA520KHK72AA
MPLA520KHK74AA
MPLA520KRJ22AA
MPLA520KRJ24AA
MPLA520KRJ72AA
MPLA520KRJ74AA
MPLA520KRK22AA
MPLA520KRK24AA
MPLA520KRK72AA
MPLA520KRK74AA
MPLA540K
MPLA540KHJ22AA
MPLA540KHJ24AA
MPLA540KHJ72AA
MPLA540KHJ74AA
MPLA540KHK22AA
MPLA540KHK24AA
MPLA540KHK72AA
MPLA540KHK74AA
MPLA540KRJ22AA
MPLA540KRJ24AA
MPLA540KRJ72AA
MPLA540KRJ74AA
MPLA540KRK22AA
MPLA540KRK24AA
MPLA540KRK72AA
MPLA540KRK74AA
MPLA560F
MPLA560FHJ22AA
MPLA560FHJ24AA
MPLA560FHJ72AA
MPLA560FHJ74AA
MPLA560FHK22AA
MPLA560FHK24AA
MPLA560FHK72AA
MPLA560FHK74AA
MPLA560FRJ22AA
MPLA560FRJ24AA
MPLA560FRJ72AA
MPLA560FRJ74AA
MPLA560FRK22AA
MPLA560FRK24AA
MPLA560FRK72AA
MPLA560FRK74AA
