Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Training - I11T11 Training Videos
Free online training on how to connect and configure the Compax3 I11T11 servo drives with simple indexer for external PLC control.
The I11T11 is the servo amplifier with simple indexer that supports external PLC control. Moves are programmed in the index chart and can be homing, absolute or incremental. These moves are selected via address inputs from external PLC. It is configured using the C3 ServoManager software but controlled from the inputs. There are dedicated inputs for the Enable/Energize, Stop (normally closed), Start (scan the address inputs for the particular move you want). You can have 31 moves stored or if using a hardware home sensor 15 moves.
The moves can be selected through the address inputs or you can set it for sequentially, where toggling the Start input would do the next move in the index chart.
Note the I12T11 is similar with the addition of having a second input connector. With the additional inputs, you gain dedicated hardware limit switch inputs, jog + and jog - inputs and 3 outputs that can be programmed to turn on and off at the end of the moves. The I12T11 can be controlled via the inputs or serially with ASCII communcation via RS232 or RS485.
Related FAQ: I12T11 or I11T11 Differences
 Playlist of all videos here or individual videos below:
MOBILE USERS CLICK HERE
Note these videos are hosted in youtube.com and would require access to this site. This is a 19 part video training in this play list. For first time users, it'd be good to watch all in sequence. For experienced users needing a refresher or looking for specific information, the lessons are broken in small sections so you wouldn't need to watch all and are shown individually below. Total time is 24 minutes.
 Alternately, these videos can be downloaded from here for PCs without internet connection:  http://www.parkermotion.com/manuals/hauser/compax3/Compax3.htm
Making Motion with the I11T11
Lesson A: C3 ServoManager
Lesson B: Drive Selection
Lesson C: Drive Configuration
Lesson D: Motor Selection
Lesson E: Motor Reference Data
Lesson F: Braking Resistor
Lesson G: External Moment of Inertia
Lesson H: Distance and Travel Parameters
Lesson I: Machine Zero and Homing
Lesson J: Travel Limit Settings
Lesson K: Jerk Ramps
Lesson L: Monitoring and Limit Settings
Lesson M: Encoder Output
Lesson N: Position Profile Configuration
Lesson O: Defining Position Profiles (Single)
Lesson P: Defining Position Profiles (Sequential)
Lesson Q: Summary Screen
Lesson R: Download Screen
keywords:
S025V2F10I11T11M00
S063V2F10I11T11M00
S038V4F10I11T11M00
S075V4F10I11T11M00
S100V2F10I11T11M00
S150V2F10I11T11M00
S150V4F10I11T11M00
S300V4F10I11T11M00
H50V4F10I11T11M00
H90V4F10I11T11M00
H125V4F10I11T11M00
H155V4F10I11T11M00
M050D6F10I11T11M00
M100D6F10I11T11M00
M150D6F10I11T11M00
M300D6F10I11T11M00
S025V2F10I12T11M12
S063V2F10I12T11M12
S038V4F10I12T11M12
S075V4F10I12T11M12
S100V2F10I12T11M12
S150V2F10I12T11M12
S150V4F10I12T11M12
S300V4F10I12T11M12
H50V4F10I12T11M12
H90V4F10I12T11M12
H125V4F10I12T11M12
H155V4F10I12T11M12
M050D6F10I12T11M12
M100D6F10I12T11M12
M150D6F10I12T11M12
M300D6F10I12T11M12
S025V2F12I11T11M00
S063V2F12I11T11M00
S038V4F12I11T11M00
S075V4F12I11T11M00
S100V2F12I11T11M00
S150V2F12I11T11M00
S150V4F12I11T11M00
S300V4F12I11T11M00
H50V4F12I11T11M00
H90V4F12I11T11M00
H125V4F12I11T11M00
H155V4F12I11T11M00
M050D6F12I11T11M00
M100D6F12I11T11M00
M150D6F12I11T11M00
M300D6F12I11T11M00
S025V2F12I12T11M12
S063V2F12I12T11M12
S038V4F12I12T11M12
S075V4F12I12T11M12
S100V2F12I12T11M12
S150V2F12I12T11M12
S150V4F12I12T11M12
S300V4F12I12T11M12
H50V4F12I12T11M12
H90V4F12I12T11M12
H125V4F12I12T11M12
H155V4F12I12T11M12
M050D6F12I12T11M12
M100D6F12I12T11M12
M150D6F12I12T11M12
M300D6F12I12T11M12
S025V2F11I11T11M00
S063V2F11I11T11M00
S038V4F11I11T11M00
S075V4F11I11T11M00
S100V2F11I11T11M00
S150V2F11I11T11M00
S150V4F11I11T11M00
S300V4F11I11T11M00
H50V4F11I11T11M00
H90V4F11I11T11M00
H125V4F11I11T11M00
H155V4F11I11T11M00
M050D6F11I11T11M00
M100D6F11I11T11M00
M150D6F11I11T11M00
M300D6F11I11T11M00
S025V2F11I12T11M12
S063V2F11I12T11M12
S038V4F11I12T11M12
S075V4F11I12T11M12
S100V2F11I12T11M12
S150V2F11I12T11M12
S150V4F11I12T11M12
S300V4F11I12T11M12
H50V4F11I12T11M12
H90V4F11I12T11M12
H125V4F11I12T11M12
H155V4F11I12T11M12
M050D6F11I12T11M12
M100D6F11I12T11M12
M150D6F11I12T11M12
M300D6F11I12T11M12
