Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Encoder & Resolver) to Parker MPP
The MPP (MaxPlusPlus) Series is the industry's highest performing servo motor. Utilizing eight-pole segmented lamination technology, the MPP produces more torque in a shorter package. Use MPP motors for higher torque applications, customization options, or when high performance is required.
The MPP Series features a new design that offers lower inertia and higher power, all in a smaller motor package. These brushless servo motors are designed for the demanding applications found in today's high performance servo systems.
The MPP motors feature segmented core technology, which can yield up to 40% higher torque per unit size than conventionally wound servo motors. Potted stators improve heat transfer for better thermal efficiency, resulting in increased torque at the motor shaft.
High-energy neodymium magnets are employed for higher rates of acceleration.
Parker will customize any MPP motor to meet your specific system requirements. Parker does customs like no one else. We are specialists at customs, offering unrivaled custom motor solutions and support.
The MPP/MPJ family of brushless servo motors redefines performance, flexibility, and reliability.
Feedback Notes:
Numerous applications have used the Kinetix drives with the MPP/MPJ series motors with our standard single-speed resolver (41) and 2000-line (pre-quadrature) encoder (1E) with hall sensors.
Absolute Encoder Notes:
The MPP and MPJ with the Compax3 support the full range of the absolute encoders of 4096 turns and support absolute position retention when the drive has been powered off.
Are MPP / MPJ with absolute encoders compatible with Kinetix drives?
MPL series motors with M are a multi-turn Stegmann Hiperface absolute encoder (4096 turns). The MPP series motors with 6S are the same model Stegmann Hiperface absolute encoder (SRM 50). Kinetix drives use a blob file that's sent from the Hiperface absolute encoder for their auto-configuration. The MPP use the standard Hiperface encoder without this blob file. Thus MPP motors with the Stegmann Hiperface multi-turn (6S) or single-turn (9S) are compatible with Parker Compax3 drives with F11 but not Kinetix drives.
Kinetix drives 300 do not support third-party motors. For 350 drives, you can check with your AB representative.
Kinetix 6200 support third-party motors with EnDat with firmware version 1.040:
Kinetix 6200 firmware note 1
Kinetix 6200 firmware note 2
Kinetix 6500 support third-party motors with EnDat with firmware version 2.005:
Kinetix 6500 firmware note 1
Kinetix 6500 firmware note 2
MPP and MPJ servo motors are available with EnDat 2.1 encoder (ECI 1331) and is the 7D order code. ie, MPP0921B7D-NPSN Note the limited Kinetix ability in using the absolute encoder function in power-off (above notes). Note the drive and cable differences per this FAQ if using Parker Compax3:
FAQ: Absolute Encoders and Drive Compatibility
Connector Notes:
Initially the MPL series motors had fixed connectors, Circular Bayonet, Facing Shaft. This was connector 2 in the part numbering: MPL-A330P-MJ22AA. Allen Bradley now has the MPL series with Circular (SpeedTec) DIN connector, right-angle 180 degree rotatable, similar style as the MPP series motor. This is connector 7 in the part numbering: MPL-A330P-MJ72AA
Click here for Compax3 Input and Control Technology Levels  (IxxTxxMxx options)
Disclaimer: This has been developed as a guide for cross referencing MPL motors to Parker motors. The motors should not be used for final motor selection unless reviewed and approved by an automation engineer. The customer is ultimately responsible for their machine design.
To use this table, hold Control key and press F. Text find will appear, something that looks like this:
Enter the MPL motor part number. The Parker motor and drive options are listed as well as the motor power and feedback cables.
460VAC Resolver & Encoder
Allen Bradley Rockwell P/N Parker P/N Hiperface feedback Parker Compax3S Single Axis Servo Drive* Parker Compax3M Multi Axis Servo Drive* Motor Power Cable P/N Feedback Cable P/N for Compax3 Feedback Cable P/N flying leads
MPL-B310P MPP0921R
MPL-B310P-HJ22AA MPP0921R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HJ24AA MPP0921R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HJ72AA MPP0921R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HJ74AA MPP0921R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HK22AA MPP0921R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HK24AA MPP0921R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HK72AA MPP0921R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-HK74AA MPP0921R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B310P-RJ22AA MPP0921R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RJ24AA MPP0921R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RJ72AA MPP0921R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RJ74AA MPP0921R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RK22AA MPP0921R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RK24AA MPP0921R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RK72AA MPP0921R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B310P-RK74AA MPP0921R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P MPP0922R
MPL-B320P-HJ22AA MPP0922R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HJ24AA MPP0922R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HJ72AA MPP0922R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HJ74AA MPP0922R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HK22AA MPP0922R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HK24AA MPP0922R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HK72AA MPP0922R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-HK74AA MPP0922R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B320P-RJ22AA MPP0922R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RJ24AA MPP0922R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RJ72AA MPP0922R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RJ74AA MPP0922R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RK22AA MPP0922R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RK24AA MPP0922R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RK72AA MPP0922R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B320P-RK74AA MPP0922R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P MPP0923R
MPL-B330P-HJ22AA MPP0923R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HJ24AA MPP0923R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HJ72AA MPP0923R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HJ74AA MPP0923R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HK22AA MPP0923R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HK24AA MPP0923R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HK72AA MPP0923R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-HK74AA MPP0923R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B330P-RJ22AA MPP0923R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RJ24AA MPP0923R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RJ72AA MPP0923R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RJ74AA MPP0923R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RK22AA MPP0923R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RK24AA MPP0923R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RK72AA MPP0923R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B330P-RK74AA MPP0923R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P MPP1002R
MPL-B420P-HJ22AA MPP1002R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HJ24AA MPP1002R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HJ72AA MPP1002R1E-KPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HJ74AA MPP1002R1E-KPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HK22AA MPP1002R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HK24AA MPP1002R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HK72AA MPP1002R1E-NPSN S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-HK74AA MPP1002R1E-NPSB S038V4F12IxxTxxMxx M050D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B420P-RJ22AA MPP1002R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RJ24AA MPP1002R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RJ72AA MPP1002R41-KPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RJ74AA MPP1002R41-KPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RK22AA MPP1002R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RK24AA MPP1002R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RK72AA MPP1002R41-NPSN S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B420P-RK74AA MPP1002R41-NPSB S038V4F10IxxTxxMxx M050D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P MPP1003R
MPL-B430P-HJ22AA MPP1003R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HJ24AA MPP1003R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HJ72AA MPP1003R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HJ74AA MPP1003R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HK22AA MPP1003R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HK24AA MPP1003R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HK72AA MPP1003R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-HK74AA MPP1003R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B430P-RJ22AA MPP1003R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RJ24AA MPP1003R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RJ72AA MPP1003R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RJ74AA MPP1003R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RK22AA MPP1003R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RK24AA MPP1003R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RK72AA MPP1003R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B430P-RK74AA MPP1003R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P MPP1152R
MPL-B4520P-HJ22AA MPP1152R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HJ24AA MPP1152R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HJ72AA MPP1152R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HJ74AA MPP1152R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HK22AA MPP1152R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HK24AA MPP1152R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HK72AA MPP1152R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-HK74AA MPP1152R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4520P-RJ22AA MPP1152R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RJ24AA MPP1152R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RJ72AA MPP1152R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RJ74AA MPP1152R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RK22AA MPP1152R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RK24AA MPP1152R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RK72AA MPP1152R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4520P-RK74AA MPP1152R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F MPP1153P
MPL-B4530F-HJ22AA MPP1153P1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HJ24AA MPP1153P1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HJ72AA MPP1153P1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HJ74AA MPP1153P1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HK22AA MPP1153P1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HK24AA MPP1153P1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HK72AA MPP1153P1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-HK74AA MPP1153P1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530F-RJ22AA MPP1153P41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RJ24AA MPP1153P41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RJ72AA MPP1153P41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RJ74AA MPP1153P41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RK22AA MPP1153P41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RK24AA MPP1153P41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RK72AA MPP1153P41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530F-RK74AA MPP1153P41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K MPP1153R
MPL-B4530K-HJ22AA MPP1153R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HJ24AA MPP1153R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HJ72AA MPP1153R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HJ74AA MPP1153R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HK22AA MPP1153R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HK24AA MPP1153R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HK72AA MPP1153R1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-HK74AA MPP1153R1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4530K-RJ22AA MPP1153R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RJ24AA MPP1153R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RJ72AA MPP1153R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RJ74AA MPP1153R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RK22AA MPP1153R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RK24AA MPP1153R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RK72AA MPP1153R41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4530K-RK74AA MPP1153R41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K MPP1154P
MPL-B4540K-HJ22AA MPP1154P1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HJ24AA MPP1154P1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HJ72AA MPP1154P1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HJ74AA MPP1154P1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HK22AA MPP1154P1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HK24AA MPP1154P1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HK72AA MPP1154P1E-NPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-HK74AA MPP1154P1E-NPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B4540K-RJ22AA MPP1154P41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RJ24AA MPP1154P41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RJ72AA MPP1154P41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RJ74AA MPP1154P41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RK22AA MPP1154P41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RK24AA MPP1154P41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RK72AA MPP1154P41-NPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4540K-RK74AA MPP1154P41-NPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B4560F Could be investigated as custom
MPL-B520K MPP1422R
MPL-B520K-HJ22AA MPP1422R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HJ24AA MPP1422R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HJ72AA MPP1422R1E-KPSN S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HJ74AA MPP1422R1E-KPSB S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HK22AA MPP1422R1E-KPSN* S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HK24AA MPP1422R1E-KPSB* S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HK72AA MPP1422R1E-KPSN* S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-HK74AA MPP1422R1E-KPSB* S075V4F12IxxTxxMxx M100D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B520K-RJ22AA MPP1422R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RJ24AA MPP1422R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RJ72AA MPP1422R41-KPSN S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RJ74AA MPP1422R41-KPSB S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RK22AA MPP1422R41-KPSN* S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RK24AA MPP1422R41-KPSB* S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RK72AA MPP1422R41-KPSN* S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B520K-RK74AA MPP1422R41-KPSB* S075V4F10IxxTxxMxx M100D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K MPP1424R
MPL-B540K-HJ22AA MPP1424R1E-KPSN S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HJ24AA MPP1424R1E-KPSB S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HJ72AA MPP1424R1E-KPSN S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HJ74AA MPP1424R1E-KPSB S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HK22AA MPP1424R1E-KPSN* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HK24AA MPP1424R1E-KPSB* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HK72AA MPP1424R1E-KPSN* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-HK74AA MPP1424R1E-KPSB* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B540K-RJ22AA MPP1424R41-KPSN S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RJ24AA MPP1424R41-KPSB S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RJ72AA MPP1424R41-KPSN S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RJ74AA MPP1424R41-KPSB S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RK22AA MPP1424R41-KPSN* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RK24AA MPP1424R41-KPSB* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RK72AA MPP1424R41-KPSN* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B540K-RK74AA MPP1424R41-KPSB* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F MPP1426P
MPL-B560F-HJ22AA MPP1426P1E-KPSN S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HJ24AA MPP1426P1E-KPSB S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HJ72AA MPP1426P1E-KPSN S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HJ74AA MPP1426P1E-KPSB S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HK22AA MPP1426P1E-KPSN* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HK24AA MPP1426P1E-KPSB* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HK72AA MPP1426P1E-KPSN* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-HK74AA MPP1426P1E-KPSB* S150V4F12IxxTxxMxx M150D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B560F-RJ22AA MPP1426P41-KPSN S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RJ24AA MPP1426P41-KPSB S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RJ72AA MPP1426P41-KPSN S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RJ74AA MPP1426P41-KPSB S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RK22AA MPP1426P41-KPSN* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RK24AA MPP1426P41-KPSB* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RK72AA MPP1426P41-KPSN* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B560F-RK74AA MPP1426P41-KPSB* S150V4F10IxxTxxMxx M150D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F MPP1428P
MPL-B580F-HJ22AA MPP1428P1E-KPSN S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HJ24AA MPP1428P1E-KPSB S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HJ72AA MPP1428P1E-KPSN S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HJ74AA MPP1428P1E-KPSB S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HK22AA MPP1428P1E-KPSN* S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HK24AA MPP1428P1E-KPSB* S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HK72AA MPP1428P1E-KPSN* S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-HK74AA MPP1428P1E-KPSB* S150V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-3B1-xx F-2C1-xx F-9F1-xx
MPL-B580F-RJ22AA MPP1428P41-KPSN S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RJ24AA MPP1428P41-KPSB S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RJ72AA MPP1428P41-KPSN S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RJ74AA MPP1428P41-KPSB S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RK22AA MPP1428P41-KPSN* S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RK24AA MPP1428P41-KPSB* S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RK72AA MPP1428P41-KPSN* S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580F-RK74AA MPP1428P41-KPSB* S150V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-3B1-xx F-2B1-xx F-9F1-xx
MPL-B580J MPP1428Q
MPL-B580J-HJ22AA MPP1428Q1E-KPSN S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HJ24AA MPP1428Q1E-KPSB S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HJ72AA MPP1428Q1E-KPSN S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HJ74AA MPP1428Q1E-KPSB S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HK22AA MPP1428Q1E-KPSN* S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HK24AA MPP1428Q1E-KPSB* S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HK72AA MPP1428Q1E-KPSN* S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-HK74AA MPP1428Q1E-KPSB* S300V4F12IxxTxxMxx M300D6F12IxxTxxMxx P-4B1-xx F-2C1-xx F-9F1-xx
MPL-B580J-RJ22AA MPP1428Q41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RJ24AA MPP1428Q41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RJ72AA MPP1428Q41-KPSN S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RJ74AA MPP1428Q41-KPSB S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RK22AA MPP1428Q41-KPSN* S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RK24AA MPP1428Q41-KPSB* S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RK72AA MPP1428Q41-KPSN* S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
MPL-B580J-RK74AA MPP1428Q41-KPSB* S300V4F10IxxTxxMxx M300D6F10IxxTxxMxx P-4B1-xx F-2B1-xx F-9F1-xx
*MPP142 motors 8mm keyed shaft as standard. Key can be removed.  For applications requiring a round shaft, this could be done as a custom motor.
9/11/13jh
keywords: AllenBradley Allen-Bradley MPL series
MPLB310P
MPLB310PHJ22AA
MPLB310PHJ24AA
MPLB310PHJ72AA
MPLB310PHJ74AA
MPLB310PHK22AA
MPLB310PHK24AA
MPLB310PHK72AA
MPLB310PHK74AA
MPLB310PRJ22AA
MPLB310PRJ24AA
MPLB310PRJ72AA
MPLB310PRJ74AA
MPLB310PRK22AA
MPLB310PRK24AA
MPLB310PRK72AA
MPLB310PRK74AA
MPLB320P
MPLB320PHJ22AA
MPLB320PHJ24AA
MPLB320PHJ72AA
MPLB320PHJ74AA
MPLB320PHK22AA
MPLB320PHK24AA
MPLB320PHK72AA
MPLB320PHK74AA
MPLB320PRJ22AA
MPLB320PRJ24AA
MPLB320PRJ72AA
MPLB320PRJ74AA
MPLB320PRK22AA
MPLB320PRK24AA
MPLB320PRK72AA
MPLB320PRK74AA
MPLB330P
MPLB330PHJ22AA
MPLB330PHJ24AA
MPLB330PHJ72AA
MPLB330PHJ74AA
MPLB330PHK22AA
MPLB330PHK24AA
MPLB330PHK72AA
MPLB330PHK74AA
MPLB330PRJ22AA
MPLB330PRJ24AA
MPLB330PRJ72AA
MPLB330PRJ74AA
MPLB330PRK22AA
MPLB330PRK24AA
MPLB330PRK72AA
MPLB330PRK74AA
MPLB420P
MPLB420PHJ22AA
MPLB420PHJ24AA
MPLB420PHJ72AA
MPLB420PHJ74AA
MPLB420PHK22AA
MPLB420PHK24AA
MPLB420PHK72AA
MPLB420PHK74AA
MPLB420PRJ22AA
MPLB420PRJ24AA
MPLB420PRJ72AA
MPLB420PRJ74AA
MPLB420PRK22AA
MPLB420PRK24AA
MPLB420PRK72AA
MPLB420PRK74AA
MPLB430P
MPLB430PHJ22AA
MPLB430PHJ24AA
MPLB430PHJ72AA
MPLB430PHJ74AA
MPLB430PHK22AA
MPLB430PHK24AA
MPLB430PHK72AA
MPLB430PHK74AA
MPLB430PRJ22AA
MPLB430PRJ24AA
MPLB430PRJ72AA
MPLB430PRJ74AA
MPLB430PRK22AA
MPLB430PRK24AA
MPLB430PRK72AA
MPLB430PRK74AA
MPLB4520P
MPLB4520PHJ22AA
MPLB4520PHJ24AA
MPLB4520PHJ72AA
MPLB4520PHJ74AA
MPLB4520PHK22AA
MPLB4520PHK24AA
MPLB4520PHK72AA
MPLB4520PHK74AA
MPLB4520PRJ22AA
MPLB4520PRJ24AA
MPLB4520PRJ72AA
MPLB4520PRJ74AA
MPLB4520PRK22AA
MPLB4520PRK24AA
MPLB4520PRK72AA
MPLB4520PRK74AA
MPLB4530F
MPLB4530FHJ22AA
MPLB4530FHJ24AA
MPLB4530FHJ72AA
MPLB4530FHJ74AA
MPLB4530FHK22AA
MPLB4530FHK24AA
MPLB4530FHK72AA
MPLB4530FHK74AA
MPLB4530FRJ22AA
MPLB4530FRJ24AA
MPLB4530FRJ72AA
MPLB4530FRJ74AA
MPLB4530FRK22AA
MPLB4530FRK24AA
MPLB4530FRK72AA
MPLB4530FRK74AA
MPLB4530K
MPLB4530KHJ22AA
MPLB4530KHJ24AA
MPLB4530KHJ72AA
MPLB4530KHJ74AA
MPLB4530KHK22AA
MPLB4530KHK24AA
MPLB4530KHK72AA
MPLB4530KHK74AA
MPLB4530KRJ22AA
MPLB4530KRJ24AA
MPLB4530KRJ72AA
MPLB4530KRJ74AA
MPLB4530KRK22AA
MPLB4530KRK24AA
MPLB4530KRK72AA
MPLB4530KRK74AA
MPLB4540K
MPLB4540KHJ22AA
MPLB4540KHJ24AA
MPLB4540KHJ72AA
MPLB4540KHJ74AA
MPLB4540KHK22AA
MPLB4540KHK24AA
MPLB4540KHK72AA
MPLB4540KHK74AA
MPLB4540KRJ22AA
MPLB4540KRJ24AA
MPLB4540KRJ72AA
MPLB4540KRJ74AA
MPLB4540KRK22AA
MPLB4540KRK24AA
MPLB4540KRK72AA
MPLB4540KRK74AA
MPLB4560F
MPLB520K
MPLB520KHJ22AA
MPLB520KHJ24AA
MPLB520KHJ72AA
MPLB520KHJ74AA
MPLB520KHK22AA
MPLB520KHK24AA
MPLB520KHK72AA
MPLB520KHK74AA
MPLB520KRJ22AA
MPLB520KRJ24AA
MPLB520KRJ72AA
MPLB520KRJ74AA
MPLB520KRK22AA
MPLB520KRK24AA
MPLB520KRK72AA
MPLB520KRK74AA
MPLB540K
MPLB540KHJ22AA
MPLB540KHJ24AA
MPLB540KHJ72AA
MPLB540KHJ74AA
MPLB540KHK22AA
MPLB540KHK24AA
MPLB540KHK72AA
MPLB540KHK74AA
MPLB540KRJ22AA
MPLB540KRJ24AA
MPLB540KRJ72AA
MPLB540KRJ74AA
MPLB540KRK22AA
MPLB540KRK24AA
MPLB540KRK72AA
MPLB540KRK74AA
MPLB560F
MPLB560FHJ22AA
MPLB560FHJ24AA
MPLB560FHJ72AA
MPLB560FHJ74AA
MPLB560FHK22AA
MPLB560FHK24AA
MPLB560FHK72AA
MPLB560FHK74AA
MPLB560FRJ22AA
MPLB560FRJ24AA
MPLB560FRJ72AA
MPLB560FRJ74AA
MPLB560FRK22AA
MPLB560FRK24AA
MPLB560FRK72AA
MPLB560FRK74AA
MPLB580F
MPLB580FHJ22AA
MPLB580FHJ24AA
MPLB580FHJ72AA
MPLB580FHJ74AA
MPLB580FHK22AA
MPLB580FHK24AA
MPLB580FHK72AA
MPLB580FHK74AA
MPLB580FRJ22AA
MPLB580FRJ24AA
MPLB580FRJ72AA
MPLB580FRJ74AA
MPLB580FRK22AA
MPLB580FRK24AA
MPLB580FRK72AA
MPLB580FRK74AA
MPLB580J
MPLB580JHJ22AA
MPLB580JHJ24AA
MPLB580JHJ72AA
MPLB580JHJ74AA
MPLB580JHK22AA
MPLB580JHK24AA
MPLB580JHK72AA
MPLB580JHK74AA
MPLB580JRJ22AA
MPLB580JRJ24AA
MPLB580JRJ72AA
MPLB580JRJ74AA
MPLB580JRK22AA
MPLB580JRK24AA
MPLB580JRK72AA
MPLB580JRK74AA
