Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Inrush Current
1.  C3S025V2
Supply voltage: 1x 230VAC
DC capacitance: 560 µF
Inrush resistor (cold): 10 Î
2.  C3S063V2
DC capacitance: 1120 µF
Inrush resistor (cold): 4 Î
3.  C3S100V2
Supply voltage: 3x 230VAC
DC capacitance: 780 µF
4.  C3S150V2
DC capacitance: 1170 µF
5.  C3S015V4 / C3S038V4
Supply voltage: 3x 400VAC
DC capacitance: 235µF
Inrush resistor (cold): 20 Î
6.  C3S075V4
DC capacitance: 470µF
Inrush resistor (cold): 8 Î
7.  C3S150V4
8.  C3S300V4
DC capacitance: 1230µF
Inrush resistor (cold): 2 Î
9/26/13jh
