Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VIDEO: How to Configure Aries Servo Drives
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)-
        • Hall-only Commutation
        • Meaning of the Status LEDs
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
This video shows how to use the Aries Support Tool software to configure a Aries servo amplifier (AR-xxAE, AR-xxAR, AR-xxSE, AR-xxSR).
Use the communications dongle (71-021609-01) and serial null modem cable (71-016939-10) to connect the Aries amplifier to a PC.
If using a PC without a 9pin COM port, use the Cables Unlimited USB2920 USB to RS232 serial adapter. This has the FTDI chipset. Other adapters may not work correctly. Specifically adapters using the Prolific chipset do not work on Windows7 or newer machines.
 MOBILE USERS CLICK HERE
How to Configure Aries (pdf)
11/8/13jh
