Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VIDEO: Basics training: GV6 or GT6 drive controllers
Basic training on how to use MotionPlanner software to upload and download motor configurations and motion programs for Parker Gemini GV6 servo amplifier and Gemini GT6 stepper drive controllers with serial communication.
Shows how to run motor with AutoRun mode (DMODE13) and basic commands using the terminal to command motion, query drive controller error report & axis status, and scaling.
Also shows the equipment required.
Related FAQs:
VIDEO: express basics training: GV or GT drives
VIDEO: express basics training: GV6K or GT6K drive controllers (serial communication)
