Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - Cabling information to ACR9000 and ACR7000 controllers
P Series Drives (PD-xxP) can be controlled from ACR7xC and ACR9000 controllers using the following cable:
71-032478-xx.....ACR9000 to Pseries (analog and step & direction), 4ft or 10ft
The cable supports both torque and step/direction mode operation. Other signals included:
ACR9000 P Drive I/O Assignment
Drive Enable SV_ON Servo On In 1
Drive Reset A_RST Alarm Reset In 4
Drive Fault ALARM Out 1
BRAKE Out 3
I/O assignment matches drive default settings.
Three external leads are provided to connect the required 24VDC source for the drive I/O:
Blue +24 VDC
White w/ Blue 0 VDC
Black Output to Brake Relay
The brake output only needs to be used if the motor has a brake.  Otherwise, terminate it and fold it back along the cable to prevent it from shorting.  Do not connect the brake output directly to a brake as it is intended to be connected to a brake relay instead.  More details on brake usage can be found in this Knowledge Base article:
Keywords:
71-032478-04
71-032478-10
71-032478
17NOV2021 DCLIFFE Various changes.
jh may 2019 add keywords
jw oct 2016
  • 71-032478-04
  • 71-032478-10
  • P Series
  • P Drive
  • ACR
  • 71-032478
  • 7000
