Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Torque and Voltage Constants
Model Kt Kb Ke
Unit Nm/Arms Vp/rad/s Ke (V/krpm)
PM-FALR5A 0.18 0.15 15.4
PM-FAL01A 0.27 0.22 23.4
PM-FAL015A 0.30 0.25 25.8
PM-FBL01A 0.36 0.29 30.8
PM-FBL02A 0.47 0.39 40.4
PM-FBL04A 0.52 0.42 44.3
PM-FCL04A 0.52 0.43 44.5
PM-FCL06A 0.53 0.43 45.3
PM-FCL08A 0.50 0.41 43.0
PM-FCL10A 0.58 0.47 49.3
