Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can the AC890 be configured as an Active Front End (AFE)?
    • AC890 Series-
Yes.  Refer to the AFE Application Note HA471427 below for details.
  • Link to document
7NOV2016 LS
  • AFE
  • 890
