Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR Gantry Lock and EPL Axes
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
The ACR's Gantry Lock feature does apply to EPL axes as well as non-EPL axes. See the ACR-View help files and the LOCK command for further details.
Note - EPL axes cannot make use of the Lock Feedback Gain but all other aspects of the Gantry Lock feature are available.
glh  10/2014  Oct 2014
