Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cables - VIDEO: How to find cables for Parker motors?
This new online video explains:
1. eCL step motor cables to connect to ACR7000 stepper
2. New spreadsheet that shows the motor power cables for new ACR7000 servo, IPA, P series, PSD, Compax3
CLICK HERE TO LAUNCH VIDEO ON YOUTUBE.COM
This online video explains how to use Parker System Solution Finder software to find cable part numbers for Parker servo motors.
Parker System Solution Finder (PSSF) supports these products: PAC320, ACR9000 Family (ACR9000, ACR9030, ACR9040, ACR9600, ACR9630, ACR9640), 6K, IPA, COMPAX3, ARIES, ARIES-EPL, E-AC, E-DC, GEMINI, ZETA, VIX
This video also shows where to find cables for motors with older connector styles, legacy servo drive amplifiers and flying lead cables:
Related FAQ: Servo Cable Selection & Drawings and Motor Pinouts
12/19/13jh
6/16/20jh
