Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Misc - User Configurable Driver User Guide (UCON)
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
The following link will allow you to download a full user guide for the User Configurable Driver (ASCII communications) which provides additional details beyond what the local help file contains.
http://www.kepware.com/Support_Center/SupportDocuments/Help/UserConfigDrv.pdf
glh Dec 2013
