Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Basic connections between an ACR9000 and Dynaserv Gen1 Drive
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
ACR9000 Pin ACR9000 Function     Standard DM/DR Pin Standard DM/DR Function
1 5VDC PWR         24 VCC
2 DC Return
3 ENC A+         13 ENC A+
4 ENC A-         14 ENC A-
5 ENC B+         29 ENC B+
6 ENC B-         30 ENC B-
7 ENC Z+         43 Index +
8 ENC Z-         44 Index -
9 5VDC PWR
10 Step+         45 Step +
11 Step-         46 Step -
12 Dir +         20 Dir +
13 Dir-         19 Dir -
14 AOUT+         49 CMD+
15 AOUT-         50 CMD -
16 Fault +         15 Ready +
17 Fault -         16 Ready -
18 5VDC PWR
19 DC Return
20 Enable -
21 Enable +         23 Servo ON
22 Reset -
23 Reset +
24 DC Return         16 Drive GND
25 Drive Talk +
26 Drive Talk -
On the ACR9000 Connector, jump pins 19 and 20 as well as 17 and 24.
glh Feb 2014
glh 2014 Feb
