Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - Simulated Encoder Output (X11)
Products: C3_I10T10
The simulated encoder output resolution represents a pre-quadrature value.
Unit: Increments per revolution / pitch
Range: 4 - 16384
Standard value: 1024
Any resolution can be set
Limit frequency: 620kHz (track A or B) i.e. , with:
max. Velocity
1024
36000 rpm
4096
9000 rpm
16384
2250 rpm
