Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to Compare two Projects to See What's Different?
      • PAM IDE-
        • Simulating a project in PAM
        • User Management in PAM
Parker Automation Manager Integrated Development Environment (IDE) includes a Compare. This is available under the Project menu.
This gives the ability for programmers to compare the open project to another project to see what's different between the devices, programs and function blocks:
11/14jh
