Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - Single Turn Absolute Encoder - Position always 0 on power-up?
If using a single-turn absolute encoder with the Compax3, set Multi-turn Emulation in the Machine Zero / Homing Mode Settings to ON.
If not, on powerup the actual position will always be set to 0.
12/14jh
keywords: multiturn sincos sine cosine endat heidenhain heidenhein stegmann stegman steggman steggmann hyperface hiperface position distance reset cycle power-up power-on hard
