Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Accessories - VM15 Breakout Modules (15pin Connectors Genders)
Rev: 2/14/2012
Product: Compax3S, Compax3H, Compax3M
The X11 and X13 connectors are female.
For screw-terminal access, use the VM15-MC-02 (M=male).
The X12 and X22 connectors are male.
For screw-terminal access, use the VM15-FC-02 (F=female).
The VM15-MC-02 or VM15-FC-02, includes a din-rail mountable screw terminal with two-foot cable (610mm).
  • X11: Analog Inputs/Encoder Output/Aux Encoder Input
  • X12: Digital Inputs/Outputs
  • X13: Feedback (resolver, encoder, hall)
  • X22: Digital Inputs/Outputs
