Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VIDEO: PAC with Compax3 EtherCAT part 2: Complete Configuration
Part 2 of 4 on how to configure the Compax3 EtherCAT (I31) for the PAC
This walks through the Complete Configuration for C3 ServoManager software and explains how to set the units to increments.
5/21/14jh
