Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VIDEO: PAC with Compax3 EtherCAT part 4: Download & Test in C3 ServoManager
Part 4 of 4
This video series shows configuring the Compax3 I31 EtherCAT units for the PAC.
Part 4 shows Downloading and how test confirm the configuration is working using C3 ServoManager's Optimization screen.
MOBILE USERS CLICK HERE
5/21/14jh
