Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPW Motors - Crossover of Allen-Bradley MPS to MPW Stainless Steel series motors
The new MPW Series extends the MPP motor family to meet the needs of those applications exposed to high pressure, highly caustic, washdown environments. Specific applications can be found in such markets as Food and Beverage, Pharmaceutical, Packaging, and any other application that may be exposed to a harsh environment (salt, fog and humidity).
  • 10 models covering three frame sizes of 90, 115, and 142 mm
  • Sealed to IP69K for 1200 psi washdown requirements
  • Potted stator design for improved thermal efficiency
  • 3.9 - 25 Nm (35 to 227 in-lbs) continuous torque (230 and 460 VAC supply)
  • Options include high resolution encoders, resolvers, and 24 V brake
  • Cable options available to plug and play with A-B Kinetix and Kollmorgen AKD drives
Parker's MPW series servo motors offer many advantages over the AB MPS series motors:
  • The Parker MPW does not have a seam on the front of the motor. Single piece construction eliminates the seam on the front of the motor. The MPS has a seam on the front of the motor that potentially is an ingress point for contamination or washdown liquids.
  • Potted construction of the MPW gives better thermal conductivity and better speed-torque performance than the MPS' servo motor in a can design
  • MPW's 300 series housing is electropolished providing smoother surface for better resistance to contaminants
  • Full range of feedback options: Stegmann Hyperface SinCos absolute (multiturn or single-turn), Heidenhain EnDat absolute (multiturn), incremental encoder or resolver. You're not locked into only Allen-Bradley drives with our motor. You can use AB Kinetic drive, our drive or other manufacturer's drives.
  • Double o-ring on rear plate of motor offers twice the protection of AB's single o-ring.
Allen Bradley Rockwell P/N Parker P/N with AllenBradley connectors Parker P/N for Parker drives Parker Compax3S Single Axis Servo Drive Parker Compax3M Multi Axis Servo Drive Motor Power Cable P/N* Feedback Cable P/N for Compax3* Feedback Cable P/N flying leads*
MPS-A330P-MJ52DA MPW0923D6S-KP1N MPW0923D6S-KPSN S100V2F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A330P-SJ52DA MPW0923D9S-KP1N MPW0923D9S-KPSN S100V2F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A330P-MJ54DA MPW0923D6S-KP1B MPW0923D6S-KPSB S100V2F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A330P-SJ54DA MPW0923D9S-KP1B MPW0923D9S-KPSB S100V2F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A4540F-MJ52DA MPW1154B6S-KP1N MPW1154B6S-KPSN S150V2F11I10T10M00 M150D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A4540F-SJ52DA MPW1154B9S-KP1N MPW1154B9S-KPSN S150V2F11I10T10M00 M150D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A4540F-MJ54DA MPW1154B6S-KP1B MPW1154B6S-KPSB S150V2F11I10T10M00 M150D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-A4540F-SJ54DA MPW1154B9S-KP1B MPW1154B9S-KPSB S150V2F11I10T10M00 M150D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B330P-MJ52DA MPW0923R6S-KP1N MPW0923R6S-KPSN S038V4F11I10T10M00 M050D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B330P-SJ52DA MPW0923R9S-KP1N MPW0923R9S-KPSN S038V4F11I10T10M00 M050D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B330P-MJ54DA MPW0923R6S-KP1B MPW0923R6S-KPSB S038V4F11I10T10M00 M050D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B330P-SJ54DA MPW0923R9S-KP1B MPW0923R9S-KPSB S038V4F11I10T10M00 M050D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B4540F-MJ52DA MPW1154P6S-KP1N MPW1154P6S-KPSN S075V4F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B4540F-SJ52DA MPW1154P9S-KP1N MPW1154P9S-KPSN S075V4F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B4540F-MJ54DA MPW1154P6S-KP1B MPW1154P6S-KPSB S075V4F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B4540F-SJ54DA MPW1154P9S-KP1B MPW1154P9S-KPSB S075V4F11I10T10M00 M100D6F11I10T10M00 P-3B1-10 F-2B1-10 F-9F1-10
MPS-B560F-MJ52DA MPW1426P6S-KP1N MPW1426P6S-KPSN S150V4F11I10T10M00 M150D6F11I10T10M00 P-4B1-10 F-2B1-10 F-9F1-10
MPS-B560F-SJ52DA MPW1426P9S-KP1N MPW1426P9S-KPSN S150V4F11I10T10M00 M150D6F11I10T10M00 P-4B1-10 F-2B1-10 F-9F1-10
MPS-B560F-MJ54DA MPW1426P6S-KP1B MPW1426P6S-KPSB S150V4F11I10T10M00 M150D6F11I10T10M00 P-4B1-10 F-2B1-10 F-9F1-10
MPS-B560F-SJ54DA MPW1426P9S-KP1B MPW1426P9S-KPSB S150V4F11I10T10M00 M150D6F11I10T10M00 P-4B1-10 F-2B1-10 F-9F1-10
* Standard cable lengths are -10 for 10-foot (3meter), -25 for 25-foot (7.6meter) or -50 for 50-foot (15meter)
6/16/14jh
