Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base HMI Battery Replacements
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
The following are the replaceable batteries for the various CTC products (legacy units)
P11 (serial number rev <200) - Tadiran TL-5186 solder in type 3.6V
P11 (serial number rev >200) - BR2032 coin cell
P12 - BR2032 coin cell
P2,3,4,5,7 (586 CPU) - Tadiran TL-5186 solder in type 3.6V
P2,3,4,5,7 (Pentium CPU) - Rayovac (or similar) BR2032 coin cell 3.0V
P9 (all types) - Rayovac (or similar) CR2032 coin cell 3.0V
PC,PS,PX (Pentium)Rayovac (or similar) CR2032 coin cell 3.0V
IPC/IPX/HPC/HPX - Rayovac (or similar) CR2032 coin cell 3.0V
EPC/EPX - Rayovac (or similar) CR2032 coin cell 3.0V
PA family - Rayovac (or similar) CR2032 coin cell 3.0V
PA2 family - Rayovac (or similar) CR2032 coin cell 3.0V
Warning! There is a silver security key that strongly resembles a battery and is in a holder similar to a battery holder. On the mother board next to the holder the word "Security" is screened onto the board. This is the runtime security key that allows Interact runtime to start. If this key is lost, damaged or fails the application will not start and give an error something like Security key missing or Security key not programmed to support this device or module. If this happens, to get the unit running again, it will be necessary to upgrade the Interact software to version 7 which no longer looks for a security key. That key has been out of production since the late 2000s and no replacements exist.
kj 6/24/2014
edited dom 02/13/2019
edited glh Oct 2020
