Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base LV/HV Motors - Stepper Motor Order Code
  • Step Motors-
    • A/AX Motors - A vs M motors
    • LV/HV Motors - Customs
    • VS Motors - Motor Cables
How to order HV and LV stepper motors
Note for shaft options:
Frame size 11, 14 and 17 are only available with -01 and -02 options. These shafts do not have flats
Frame size 23 is only available with -01 and -02 options. The front shaft includes a single flat
Frame size 34 is available with all options. -01 and -02 includes two flats on the front shaft. -03 and -04 have a round front shaft and is recommended for all Parker mechanics
Nema34  option -01 and -02 (front shaft detail only)
Nema34  option -03 and -04 (front shaft detail only)
09-jul-2014 jw
