Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Powerstation Shell on older CTC units
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IXA / PCA+
Older Interact units (P1-P9) used Powerstation Shell instead of Machineshop Shell.
If exiting the Interact Application Manager puts you to the DOS prompt, just type "PSU /Z" then ENTER key to get into the Powerstation Shell.
