Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AR-20 and AR-30 minimum AC voltage
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
Minimum AC voltage for the 2000watt and 3000watt Aries models (AR-20AE, AR-20SE, AR-30AE and AR-30SE) is 160vac. Below this AC voltage level, the drive's firmware will have a low voltage fault.  The AR-30 requires 3phase input. The AR-20 can be run with 1phase (single phase) or 3phase.
This info was in revision E of the user guide but removed at the request of Underwriter's Laboratory (UL).
7/18/14jh
