Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - 24 Volt Step & Direction Inputs (Pulldown Resistor May be Needed)
For 24volt step & direction mode, note a pull-down resistor may be necessary between step input x12/13 and common x12/15 for higher speeds. This would depend upon the external device but typical a 2.2kohm resistor could suffice.
9/23/14jh
