Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Motor Connector Pinouts
SM BE NeoMetric/J series Connector Pinout drawing for connector options: LC, PS, GS, MS, FL, FO, 10, 25
88-024328-01 Rev B
For MPP/MPJ series, see catalog brochure, page 20, available on the product page.
