Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VIDEO: Run an AC30V an AC Induction motor via EtherCAT with a PAC
The PAC can be used with EtherCAT to control the Parker SSD AC30 drives that have an EtherCAT option. The AC30 is a variable speed drive for AC induction motors.
Here is a sample program for PAM1.4: AC30_InductionMotor_EtherCat_PAM1.4
Click here to see a video of a PAC with AC30 with AC induction motor: MOBILE USERS CLICK HERE
Programming Tip: Save Time by reusing Code (Export / Import Programs & Function Blocks)
2/15jh
1NOV18
  • vfd
  • variable
  • AC30
  • frequency
  • speed
  • inverter
  • drive
  • sample
