Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC CNC visualization
The port to connect to the CNC visualization on the PAC is 8080.
Thus, if using the default ip address, users may connect via:
http://192.168.10.50:8080/webvisu.htm
If using the default ip address, to launch full-screen Internet Explorer:
"C:\Program Files\Internet Explorer\iexplore.exe" -k http://192.168.10.50:8080/webvisu.htm
Related FAQs:
PAC CNC & Multi-Axis capabilities, sample & video demo
This requires the W web visualization option in the PAC part number, such as PAC320-CWN21-3A
If not, a License Expired error will appear as it isn't installed:
2/15jh
