Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to make comments in PAC software
      • Programming Tips-
        • ANY Data Type
        • C0046: Identifier 'xxxx' not defined - precompile error in PAM 1.3.0
        • How can I monitor cycle time in the PAC?
        • How do I use function block methods in CFC?
        • How to make comments in PAC software
        • How to program a Start, Stop, Reset Cold from within a PAC project
        • IDE Login Status
        • IDE User Management
        • Known issue with MC_Stop and MC_Home in PAM 1.3.0
        • Programming Tip: Save Time by reusing Code (Export / Import Programs & Function Blocks)
        • Programming Tip: Save Time on Naming Variables through Export/Import Mappings .csv
        • Variable size arrays
In program comments can be made severals ways with IEC programming within PAC software depending upon the language for the POU.
Structured Text ST:
(* Everything inbetween parentheses with star is a comment
and can be a multiline comment
These will automatically change to italic green font by default*)
This method is a good way to comment out multilines of Structured Text programs during debug quickly.
//  Single line comments can be started with two forward slashes
example:
Ladder Logic LD:
Right-click to add a label and within the label either the // or the (* *) format can be used:
Network rungs can be commented out by right-clicking and selecting Toggle Network Comment State. Note this is done on the left side with the network rung number.
Continuous Function Chart CFC:
Comments can be made using a comment box:
Note: User documentation can also be included of any file type in addition to networked documents. For details see this FAQ:
How to Link or Embed External Files within PAC Projects
1/15jh
