Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Sample Ladder Logic LD Program: Time based counter
Here's a simple sample Ladder Logic LD program. It starts when the PLC application starts and increments a counter variable every second. Select the project that matches your version of Parker Automation Manager:
PAM1.4: Counter_LD_PAM1.4
PAM1.2: Counter_LD_PAM1.2
Note this includes a Global Variable List (GVL) that has the CounterPLC variable (double integer DINT type). With it in the GVL, this will be available to other programs in the application.
Note: A PAC320 hardware controller isn't necessary to run this.See below for details:
For PAM1.4:
Under the "Online" tab at the top of the PAM window, make sure "Simulation" is checked. Whenever you go to login now, PAM will run a simulated device to run your project. Make sure to uncheck this box when you want to connect and login to a physical PAC.
For PAM1.3 or earlier:
You can use an application with a CODESYS Control Win V3 device (You must add this). Under Online > Simulation. Then you can after Build (F11), click Online > Login. This will create a virtual PLC and allow you to run PLC simulation (Play or F5). Here's a screen capture and project archive:
1/15jh
30OCT18 JD
  • LD
  • PAC
  • diagram
  • counter
  • Ladder
  • sample
