Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Accessories - Options and Drawings
CN1 Drive 50 pin I/O Connector.......PD-xxP (pulse/direction/indexer)
3 options for connection:
-Breakout board with 0.5m cable.....APC-VSCN1T05   (part number changed from APC-VSCN1T
-Connector with flying lead cable, APC-CN102A  (2m long) or APC-CN105A (5m  long)
-Connector only (solder leads) APC-CN1NNA
CN2 Drive 20 pin I/O Connector.......PD-xxC (EtherCAT)
-Connector with flying lead cable, APCS-CN102A  (2m long) or APCS-CN105A (5m  long)
-Connector only (solder leads) APC-CN2NNA
-No breakout available at this time.
 Breakout board with cable.....APC-VSCN1T05
These cables on the flying lead side, each wire lead are individually labeled.
APC-CN10xA Color codes (.pdf)
Color codes:
Pin Wire Color Marking
1 Orange 1 Blk Dot
2 Orange 1 Red Dot
3 Orange 2 Blk Dash
4 Orange 2 Red Dash
5 Orange Blk Dash Dot Dash
6 Orange Red Dash Dot Dash
7 Orange 4 Blk Dot
8 Orange 4 Red Dot
9 Orange Blk Continuous Dash
10 Orange Red Continuous Dash
11 Yellow 1 Blk Dot
12 Yellow 1 Red Dot
13 Yellow 2 Blk Dash
14 Yellow 2 Red Dash
15 Yellow Blk Dash Dot Dash
16 Yellow Red Dash Dot Dash
17 Yellow 4 Blk Dot
18 Yellow 4 Red Dot
19 Yellow Blk Continuous Dash
20 Yellow Red Continuous Dash
21 Gray 1 Blk Dot
22 Gray 1 Red Dot
23 Gray 2 Blk Dash
24 Gray 2 Red Dash
25 Gray Blk Dash Dot Dash
26 Gray Red Dash Dot Dash
27 Gray Blk stripe
28 Gray 4 Red Dot
29 Gray Blk Continuous Dash
30 Gray Red Continuous Dash
31 White 1 Blk Dot
32 White 1 Red Dot
33 White 2 Blk Dash
34 White 2 Red Dash
35 White Blk Dash Dot Dash
36 White Red Dash Dot Dash
37 White 4 Blk Dot
38 White 4 Red Dot
39 White Blk Continuous Dash
40 White Red Continuous Dash
41 Pink 1 Blk Dot
42 Pink 1 Red Dot
43 Pink 2 Blk Dash
44 Pink 2 Red Dash
45 Pink Blk Dash Dot Dash
46 Pink Red Dash Dot Dash
47 Pink Blk Stripe
48 Pink 4 Red Dot
49 Pink Blk Continuous Dash
50 Pink Red Continuous Dash
Connector with flying lead cable, APCS-CN102A or APCS-CN105A
APCS-CN10xA Color codes (.pdf)
Color codes:
1 Yellow 1 Blk Dash
2 Yellow 1 Red Dash
3 Yellow 2 Blk Dash
4 Yellow 2 Red Dash
5 Yellow 3 Blk Dash
6 Yellow 3 Red Dash
7 Yellow 4 Blk Dash
8 Yellow 4 Red Dash
10 Yellow Red Continuous Dash
11 White 1 Blk Dash
12 White 1 Red Dash
13 White 2 Blk Dash
14 White 2 Red Dash
15 White 3 Blk Dash
16 White 3 Red Dash
17 White 4 Blk Dash
18 White 4 Red Dash
19 White Blk Continuous Dash
20 White Red Continuous Dash
