Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SMC_ERROR.SMC_FB_WASNT_CALLED_DURING_MOTION
This error occurs when a motion function block, such as MC_MoveRelative or MC_MoveAbsolute is called outside the EtherCAT_Master task.  All motion has be called from the EtherCAT_Master.
From this image, you can see the RunMotion_CFC is inside the MainTask which is the problem. Users can click these Program calls under the Task Configuration to drag and drop. Moving this into the EtherCAT_Master and then compiling would fix this error.
8/28/15jh
Keywords:
SMC_ERROR
SMC ERROR SMC FB WASNT CALLED DURING MOTION
