Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Training - Importing Tags into Xpress from Control Logix / Compact Logix
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
This document will describe the steps needed to take an Excel File of Tags Exported from a ControlLogix or a CompactLogix PLC and reorganize for importing into the PFD Manager. The concepts will apply to Tags exported from any of the common PLCs.
Importing Tags into Xpress.pdf
 Video tutorial:
Video courtesy of our high tech automation partner Olympus Controls.
Olympus Controls is part of our network of Automation Technology Centers, offering local expertise in automation and motion control with on-staff engineers to partner with you to complete your automation and machine projects.
Control Logix or a Compact Logix , Allen Bradley, AB, A-B, Allen-Bradley, AllenBradley, Rockwell Automation
 Xpress Express CTC HMI Human Machine Interface Operator interface
tags variables PLC data machine control
8/10/15jh
