Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - How to Home to a Hardstop
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Here are sample programs on how to home to a hardlimit in AcroBasic for the IPA:
Home to a Hardstop in Positive Direction (.txt)
Home to a Hardstop in Negative Direction (.txt)
9/9/15jh
