Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC with Cognex Camera
      • 3rd Party Samples-
        • PAC with Baumer vision inspection
        • PAC with Cognex Camera
        • PAC with Turck Modular I/O System
        • PAC with Wago EtherCAT IO
Here's a Parker PAC controller connected to a Cognex In-Sight 5000 camera for visual inspection and how to set it up and connect, using Modbus TCP. Courtesy of our high tech automation partners IP Tech (In Position Technologies).
IP Tech is part of our network of Automation Technology Centers, offering local expertise in automation and motion control with on-staff engineers to partner with you to complete your automation and machine projects
PAC to Cognex Setup Instructions
 CLICK HERE FOR LINK TO VIDEO ON YOUTUBE.COM
9/19/15jh
