Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC with Baumer vision inspection
      • 3rd Party Samples-
        • PAC with Baumer vision inspection
        • PAC with Cognex Camera
        • PAC with Turck Modular I/O System
        • PAC with Wago EtherCAT IO
Here's a Parker PAC controller connected to a Baumer camera for visual inspection and using discrete IO. Courtesy of our high tech automation partner Pacific Technical Products (PTP).
Pacific Technical is part of our network of Automation Technology Centers, offering local expertise in automation and motion control with on-staff engineers to partner with you to complete your automation and machine projects
CLICK HERE FOR VIDEO ON YOUTUBE.COM
9/19/15 jh
