Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - Ballscrew Compensation / Slope Correction
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Attached is an example of using ballscrew compensation for the IPA's AcroBasic language (also used by the ACR9000/ACR7000 products). This can be used with a precision tables slope graph to then correct for stage inaccuracies to achieve higher accuracies:
Linear Compensation (.pdf)
9/28/15jh
