Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC Web Visualization with Internet Explorer: missing browser feature HTML5-Canvas Webvisu
In the event of Internet Explorer (vers 11) error:
Webvisu not supported due to missing browser feature HTML5-Canvas Webvisu not supported due to missing browser feature HTML5-Canvas
Change the IE compatibility settings for intranet pages OFF:
Then the web visualization for CNC will work:
Note: Chrome vers 45 does not have this issue.
10/13/15jh
