Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Hardware - Connector Part Numbers
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
      • IPA Troubleshooting - I am able to ping my IPA but it will not connect to PMM.
Product C2 Connector Part Number Available for Purchase? Quantity per Drive Description Function Phoenix Part No. PCD Part No. OST Part No.
IPA04-HC or IPA15-HC 43-021069-01 Yes 1 CONN,7P,PLUG,.200,BLK,FLNG,MNT MAINS POWER   NON-ROHS: ELFP07210E    ROHS: OSTTJ075102
  43-021068-01 Yes 1 CONN,6P,PLUG,.200,BLK,FLNGE MNT MOTOR POWER   NON-ROHS: ELFP06210E   ROHS: OSTTJ065102
  43-032404-01 Yes 1 CONN,2PIN,3.5MM,SPRING HIPERFACE DSL 1826680
  43-032405-01 Yes 1 CONN,2X6PIN,3.5MM,SPRING TORQUE ENABLE & ANALOG INPUT 1708577
R-clamp (EMI/RF ground)   part number: 52-019734-01
   Size for fastener for R-clamp: 8-32x3/8 Pan Head
11/3/15jh
