Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Single Axis Sample Program with Visualization
Sample program showing first steps of energizing a servo/stepper axis with a Continuous Flow Chart (CFC) program with MC_Power and commanding motion via MC_MoveAbsolute or MC_MoveVelocity function blocks.
Axis is set as a Modulo axis. Commanding MC_MoveAbsolute while motor is jogging with MC_MoveVelocity will interrupt that move and complete the move to the absolute 180degree position (dynamic positioning). MC_MoveAbsolute direction input can be changed for current direction, positive or negative direction or shortest path.
MOBILE USERS CLICK HERE
Similar to sample projects installed when Parker Automation Manager software is installed. Default location:
C:\Program Files (x86)\Parker Hannifin\ParkerAutomationManager\CODESYS\Projects\SoftMotion\Examples\Tutorial
11/17/15jh
