Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Motor Files and Setup for MPP / BE / SM / J / N / mSR / mPR / LXR / 110 / 210 / 310 / 410 / T1 / T2 / T3 / T4 Motors (Incremental Encoders w/ Halls)
Products: P Series Drives, PD-xxP, PD-xxC, MPP/MPJ, BE, SM, mPR, mSR, 400LXR servo motors
P Series Servo Drives can be configured for use with standard Parker motors such as the BE, SM and MPP/MPJ families. Incremental encoders are supported beginning with Firmware version 0.81.
Factory designed cables are available. Part number F-4A1-xx for PS connectorized motors with incremental encoders.
Motor Configuration Files
  • Motor Configuration with Parker MPP/BE/SM/J/N servo motors, mSR Linear Motor stages, mPR miniature rotary precision stage, LXR series linear motor stages, IForce and Ripped linear motor/motor stages:
    • MotorFiles.zip
    • NEW!!! - XLM Motor Files
  • "How Do I load Motor files using Drive Support Tool?"
    • How to load motor files using Drive Support Tool
  • Quick setup file for base drive configuration:
Existing Parker feedback cables can be modified with the addition of the drive side connector. Connector kits for the drive feedback connector are available for purchase:
  • APC-CN3NNA Drive Feedback Connector, 14-pin
Cable Color code references.
PS Feedback P Drive
Pin Function PIN#
1 ENC A- 12
2 ENC A+ 13
4 Hall 1 5
5 Hall 2 3
6 Hall 3 1
7 DGND 7
8 +5 VDC 14
9 TEMP
11 ENC B+ 11
12 ENC B- 10
13 TEMP
14 N/C
15 ENC Z+ 9
16 ENC Z- 8
17 N/C
Above wiring requires the drive to be configured for
Encoder Type= Quad. B leads A
Hall Offset = 330 degrees
17-Nov-2015 jw
24-Sep-2019 jh  Rev3 motor files added
06-Jul-2020 DCLIFFE Rev4 motor files added.  Updated metadata.
15-Jun-2021 DCLIFFE Updated motor file link to HTTPS.
23-Jun-2021 jh Rev5 motor files added.
  • motor
  • file
  • pseries
