Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Minimum Internet Explorer version for Xpress and Visualization options
Minimum requirement for embedded Xpress option for PAC controller is IE8 and Flash Player 10.1 on the PC.
For embedded WebVisualization, browser needs to support HTML5:
http://msdn.microsoft.com/en-us/library/ie/ee330730%28v=vs.85%29.aspx#browser_emulation
11/18/15jh
