Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - How to Save Servo Gains
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
The IPA servo gains can be stored with the ESAVE command.
This is different than the Aries Controller (AR-xxCE) but like the ACR9000.
Related FAQ: ACR Memory usage and commands
12/17/15jh
