Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can I run the MX80L using a Gemini Drive?
No. The MX80 requires a very low voltage digital drive. Using a Gemini will burn up the motor. The ViX drives or the Compax3 are compatible.
The Compax3 powered can be powered with DC voltage (no hardware changes necessary) and is now released and available.
