Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Hardware - Does the IPA Have Battery Backed Memory or Flash?
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
No, the IPA uses flash memory.
There is no battery within the IPA (unlike the ACR9000 series: 9x00xxxBx model numbers)
If making quick program changes and testing, you can uncheck it. Just be sure to check it to save to flash before cycling power (or REBOOT) once you've got your program the way you want it.
12/21/15jh
