Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - EtherCAT Version - Safety Rating
P Series EtherCAT drives (PD-04C, PD-10C, PD-35C)
STO (safe torque off) in accordance with  EN ISO13849-1:2008/AC, SIL2, Category3, PLd, EN61800-5-2:2007
jw 2016-01-19
