Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I copy the configuration of one drive to another using the keypad?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
This document explains how to copy one drive configuration to another using the keypad. Note: Version 8 is very likely required.
  • Link to document
13SEP2016 LS
  • copy
  • 590+
  • keypad
  • configuration
