Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the maximum operating altitude for the AC890?
    • AC890 Series-
A. The maximum operating altitude for an AC890 is 2000m (6500 ft.).
Note: The drive has to be derated linearly 1% per 100 meters above 1000m to a MAXIMUM of 10% at 2000m (6500 ft.).
B. The maximum operating altitude for an 890PX is 4600m (14950 ft.).
Note: The drive has to be derated linearly 1% per 100 meters above 1000m to a MAXIMUM of 36% at 4600m (14950 ft.).
13SEP2016 LS
  • 890PX
  • operating
  • altitude
  • 890
